Results 1 to 3 of 3
Thread: Dumb question...
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default Dumb question...
    I was looking over the supported vehicles list, and noticed that the V1 does not support the 98-00 Vortec PCMs. Why is this? The newer LS2 PCMs are obvious (CAN), but IIRC, the 98 Vortec PCM uses VPW just like the LS1 PCMs.
    Just curious.
    Sep 2005
    I believe Ross said they had connectivity issues with the V1 and the Vortec PCM's, but not with the V2's even though they are VPW, So they were only able to make them work with the V2.
    He could explain it better, but he had a good reason.
    Aug 2005
    Quote Originally Posted by kbracing96
    Yep, it was an issue with reading and flashing. You can still use a V1 to scan though.
  1. Dumb question...
    By 8100 Power in forum FlashScan V2 BB Logging
    Last Post: September 30th, 2008, 04:56 PM
  2. New guy, dumb question
    By Pipeliner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 14th, 2007, 08:20 PM
  3. Probably a Dumb question...............
    By FreddyG in forum Petrol / Gas
    Last Post: September 17th, 2007, 03:47 AM
