Results 1 to 3 of 3
Thread: E85 users?
    Lifetime Member N0DIH's Avatar
    Jan 2006
    Default E85 users?
    Are there any users of E85 here?
    I use it off and on depending on the gas prices. Pretty much as long as gas stays more than $0.50 more a gallon, it is break even with E85 use. More than that is cost savings. And less $ into the middle eastern economy is always a benefit...
    Drivability is excellent. MPG is down roughly 2 mpg, sometimes as much as 3, on a bad day, 4. But never worse than 4 mpg loss.... Power is up a tad too.
    And can anyone explain how GM handles E85 in the FFV vehicles? Do they use a separate E85 timing map, or just out of nature does it just use the high octane timing map?
    Thanks!
    Sep 2005
    I would run it if i could get it. My turbo would LOVE it. The older FFV have a fuel composition sensor that tells it how much ethanol there is in the fuel, the newer ones, just guess from from what I've heard, cuz they no longer use the fuel comp sensor. Basically from what I've read every time you fill it up, it resets the fuel trims and then uses them and the O2's to determine how much ethanol is in the fuel by how far off it is and then makes a more semi permanent adjustment until you fill up again.
    Jan 2006
    Can the Virtual Fuel Sensor tune be used on the the 0411 PCM? Or is that a newer PCM with more memory?
  1. Thanks to EFI and its tech users...
    By TFZ_Z06 in forum Lounge
    Last Post: April 11th, 2010, 11:27 AM
  2. Most users ever online...
    By joecar in forum Lounge
    Last Post: January 29th, 2009, 03:35 PM
  3. CO5 users in here please.
    By articSS in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 10th, 2008, 04:49 AM
  4. For you V2 users (in waitng)
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 03:22 AM
  5. LM1 users
    By Highlander in forum General
    Last Post: November 7th, 2005, 12:57 PM
