I am needing some help on my initial startup. It will now crank and fire and run for a few seconds then stall unless I give it gas. Sometimes I have to give it gas to start it. Once its running I gotta keep the rpms up for about 15seconds then slowly bring it down... or it will stall. Does not matter if its a cold start, or a hot start(hots slightly better).
I have adjusted B3201 to add a bit more fuel, helped a bit.
I have adjusted B3604 from 10c to 50c across the board to add more fuel. Helped a bit also.
But now I'm thinking, since it will start, thats not the area I need to tackle. Either way I went with them 2, I still have to keep the rpms up for a bit or it will stall. Where do I need to edit?
Attaching my first attempt at a scan and log file. If there is a pid(s) that is not shown that you need, please let me know and I will re-log.
Vin for log is 1ghg39r611104618
os 12212156
It is installed on a 350 TPI engine.
