Results 1 to 10 of 11
Thread: deleting a tune
    Member way2much_01's Avatar
    Sep 2007
    Default deleting a tune
    anyone know how to delete a tune it's a mail order tune and they locked it. I know theres a way to delete it and start all over I just dont know how. any help is appreciated.
    Jun 2005
    I think you have to do a full reflash with a new file over top of the locked one. It should take like 3~4 minutes instead of the 30 seconds that a quick flash takes.
    Sep 2007
    how do I do that?
    Jun 2005
    Well, you need the Commercial version/license. It allows you to do a few more things than the Personal version does (like full flashes, custom operating systems, etc.). If you have that, then to do a full flash, you connect Flashscan to the vehicle/laptop, load the tuning software with the tune you want to load, click Flash (in the menu bar at the top), and select "Program PCM operating system and calibrations..." - OR you can hit Ctrl+Alt+PgDn as a shortcut.
    Sep 2005
    You can't write over a locked tune, even with a full rewrite. The locking of the PCM grants you no access to it for reading or writing. You have to have the original tuner unlock it, or get a different PCM.
    Aug 2005
    Quote Originally Posted by kbracing96
    I agree, but if the tuner used EFILive call them and have them tell you the key they used so you can unlock it yourself. Otherwise they will have to unlock it for ya.
    Sep 2007
    I heard that it would have to be completely deleted and then a new tune uploaded in order to do it but I don't know how to do that.
    Sep 2005
    Quote Originally Posted by way2much_01
    The only time the flash chip is "deleted" or "erased" is right before a the flashing or writing over of a new tune and you need the proper seed key to be granted access to the flash chip unless you desodder the flash chip from the board and completely reprogram it. If your tune is locked and you don't know who or what was the last to tune it, then you have no chose but to get another PCM and start over. Other wise contact the previous tuner and see if you can have THEM unlock it as they are the only ones who can do it.
    Oct 2006
    http://wiki.xtronics.com/index.php/How_EPROMS_Work
    Don't know about the erasing stuff .
    2006 Trailblazer
  1. Deleting Rear 02's
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2009, 07:54 AM
  2. Deleting MAF
    By v8vegaman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2007, 01:44 AM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
  5. Deleting Logged Data Problem?
    By BowlingSS in forum General
    Last Post: July 29th, 2005, 08:13 AM
