Results 1 to 5 of 5
Thread: Need help PCM lost
    Junior Member ripmf666's Avatar
    Dec 2006
    Default Need help PCM lost
    Heres what im getting trying to load tune in from my efi live
    05:04:15.015: Scanning for EFILive FlashScan V2 USB
    05:04:15.265: Current protocol set to: "ISO 15765 CAN"
    05:04:15.312: Interface firmware version: 2.4.61
    05:04:15.343: Interface firmware model: FS2
    05:04:15.375: Interface firmware version: 2.4.61
    05:04:15.390: Interface firmware date: Jul 24, 2007
    05:04:15.406: FlashScan serial number: 003610363660
    05:04:15.421: FlashScan license number: 003610363660
    05:04:15.453: Disconnecting ...
    05:04:15.500: Disconnected
    05:04:16.046: Scanning for EFILive FlashScan V2 USB
    05:04:16.281: Current protocol set to: "ISO 15765 CAN"
    05:04:16.328: Interface firmware version: 2.4.61
    05:04:17.953: Current protocol: "ISO 15765 CAN"
    05:04:17.984: Interface firmware model: FS2
    05:04:18.015: Interface firmware version: 2.4.61
    05:04:18.031: Interface firmware date: Jul 24, 2007
    05:04:18.062: FlashScan serial number: 003610363660
    05:04:18.078: FlashScan license number: 003610363660
    05:04:19.734: Current protocol set to: "ISO 15765 CAN"
    05:04:19.781: Interface firmware version: 2.4.61
    05:04:21.437: Getting status...
    05:04:22.015: Status: Calibration missing.
    05:04:27.312: Preparing ECM for reflash...
    05:04:27.359: ECM seed is: $4D8C
    05:04:27.750: Initializing ECM...
    05:04:28.875: Request GM operating system...
    05:04:28.921: GM operating system: 0
    05:04:29.500: Request serial number...
    05:04:30.375: Reflashing ECM's memory...
    05:04:32.437: Erasing ECM flash memory... (please wait up to 45 seconds)
    05:04:33.312: ECM flash memory erased OK
    05:04:33.406: Error: Failed. Controller has returned to normal operation, please retry the operation.
    05:04:33.406: Reflash failed, aborting...
    05:04:33.421: Total time: 00:00
    05:04:33.421: Data compression achieved: 0.0%
    05:04:33.437: Attempting to reboot ECM... (please wait up to 8 seconds)
    05:04:34.593: ECM has booted successfully...
    05:04:35.609: Clear emisison related DTCs...
    05:04:37.203: Current protocol set to: "ISO 15765 CAN"
    05:04:37.265: Interface firmware version: 2.4.61
    05:04:38.093: Clear DTCs for all modules...
    05:04:39.671: Current protocol set to: "ISO 15765 CAN"
    05:04:39.718: Interface firmware version: 2.4.61
    05:04:40.843: Reflashing completed successfully
    05:04:43.609: Done!
    Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
    EFI Live tuned by IdahoRob,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter.
    Alot Of thanks To George aka BigDipper,Guy at Socal Diesel.
    RIP LBZ 6/1/08@5:44pm she was strong
    She's Alive again
    Born on July 27, 2008, 11:59:02 PM
    Are you saying that it failed to flash...?
    I pm'd Tech Support.
    Dec 2006
    took out one program and went to load stock file and would not load truck is acting like there is no vin in pcm now and no gm OS.
    She's Alive again
    I take it truck will not start...
    leave battery connected;
    pull PCM/ECM fuse for 1 minute and then reinstall;
    see if truck starts now.
    Aug 2004
    The pcm has been erased, but in the middle it looks like another module tried to talk and reset itself and the other modules during that process.
    You need to pull the fuses for your aftermarket radio and try it again. that is if you have an aftermarket radio.
  1. HELP: I am lost !
    By Lennart in forum Gen III V8 Specific
    Last Post: June 28th, 2010, 01:51 AM
  2. new and lost
    By WARDEN in forum Vortec V6/V8 Specific
    Last Post: May 19th, 2008, 10:09 AM
  3. Lost in the wilderness (V1 -> V2)
    By critter in forum FlashScan V2
    Last Post: September 11th, 2007, 01:14 PM
  4. im so lost
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2007, 04:10 AM
  5. Ok I'm Lost
    By TLKSCHP in forum General
    Last Post: September 30th, 2006, 10:57 AM
