Originally Posted by
louis
Hello.
Here is the results changing B4349 table from .0136 to .0310.
I went up slowly while the car was still warm. (Worried about hign screaming starts) At .0255 I could see iacdes_B .85 lbs/min start getting way out of sync with dynair 1.80.
Moving up to .0300 and after readjusting B4307, B4308 and B0101 from logged maps I started to get a flare and high idle up to 2000 rpms.
I brought it up to B4349 .0310 and the idle started rising past 2500 rpms. Seems the max idle table does not have ant different effect on my high idle starts. I could not get the idle down unless I held my foot on the brake which must lower the vacuum or something.
Checking iacdes_B was at .66 vs dynair was at 1.70 lbs/min. I tried every adjustment I could think of to bring these numbers closer together but nothing helped.
Is there something else I am missing here or am I thinking the wrong thing by trying to make the iacdes_B and dynair the same?
Even at .0310 I would still get reduced power mode and sometimes a P1221 code but not always and only at the water temp of above 80C.
Could a bad tac cause this and only at this temp act up? I cannot fathom that if sometimes it will run past 80C also. I am going to check the voltage on the sensor and the actuator and keep you posted.
Thanks for all your help so far.
Louis
