Results 1 to 8 of 8
Thread: Reset DTCs
    Oct 2006
    Default Reset DTCs
    After updating to 7.5.1 (24) from 7.5.1 (21) , I get DTCs several P0000 , when I try to reset the codes the DTCs keep triggering again .
    Did I miss something with this upgrade ?
    2006 Trailblazer
    Aug 2007
    I just did the exact same update to my EFILive version and FlashScan V2 and have received no DTC's. I dont have a 1500HD, rather I have a 2002 F-body. Did you try reflashing maybe?
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
    Oct 2006
    Quote Originally Posted by Goldfinger911
    Yes !
    First thing , even does it when I load the COS3 , like the DTC are stuck on on in the PCM .
    They even remain when I flash the PCM with a COS3 , only difference is I get a additional P0xxx code P0103 which is expected (MAF failure SD) .
    They are the same as the modules listed in the OBDII "On-board modules" list in the Scan Tool , why have they never showed before and now they do ?
    What would cause them to trigger ?
    2006 Trailblazer
    Oct 2007
    I have FlashScanV1 on a 2004 GTO and get the first code you have listed. Is there an update 'bug'?
    Ryan
    1970 El Camino *Stolen*
    2004 GTO M6
    Oct 2006
    Access denied to that link .
    2006 Trailblazer
    Red face
    Oh, my apologies, I wasn't paying attention...
    Here it is:
    It looks like an error in the EFILive software.
    Code P0000 is the code that the PCM sends to indicate "end of DTC list".
    Please ignore it until it is fixed in the next release.
    Oct 2006
    Here it is:
    Thanks joecar . Wish I could afford a Stream to be able to access the area .
    Me no worry now .
    2006 Trailblazer
  1. ATS turbo on LBZ with DTCs?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2009, 02:12 AM
  2. Not reading DTCs
    By jtaylor111 in forum FlashScan V2
    Last Post: October 11th, 2008, 05:37 PM
  3. Engine Diagnostics/DTCs
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 27th, 2008, 04:35 PM
  4. Getting DTCs from traction control?
    By derekf in forum Gen III V8 Specific
    Last Post: February 23rd, 2008, 08:06 PM
  5. Requested DTCs for modification (LBZ)
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2007, 04:57 PM
