After updating to 7.5.1 (24) from 7.5.1 (21) , I get DTCs several P0000 , when I try to reset the codes the DTCs keep triggering again .
Did I miss something with this upgrade ?
2006 Trailblazer
I just did the exact same update to my EFILive version and FlashScan V2 and have received no DTC's. I dont have a 1500HD, rather I have a 2002 F-body. Did you try reflashing maybe?
2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
Check Out My Latest Tune File: HERE
Yes !Originally Posted by Goldfinger911
First thing , even does it when I load the COS3 , like the DTC are stuck on on in the PCM .
They even remain when I flash the PCM with a COS3 , only difference is I get a additional P0xxx code P0103 which is expected (MAF failure SD) .
They are the same as the modules listed in the OBDII "On-board modules" list in the Scan Tool , why have they never showed before and now they do ?
What would cause them to trigger ?
2006 Trailblazer
I have FlashScanV1 on a 2004 GTO and get the first code you have listed. Is there an update 'bug'?
Ryan
1970 El Camino *Stolen*
2004 GTO M6
See this: showthread.php?p=58313#post58313
Access denied to that link .Originally Posted by joecar
2006 Trailblazer
Oh, my apologies, I wasn't paying attention...
Here it is:
Originally Posted by Blacky
Thanks joecar . Wish I could afford a Stream to be able to access the area .Originally Posted by joecar
Me no worry now .
2006 Trailblazer
