Results 1 to 8 of 8
Thread: Chart For Where Tables
    Oct 2007
    Default Chart For Where Tables
    Is there any list of where table names are located at?
    example
    B3604 = Engine Cal > Fuel > Crank Start > Commanded Fuel When Cranking
    In my searchings I see things going by that number(understandably), and I sometimes find it hard to find them.
    11 Silverado
    08 Sierra
    91 RS with 350 TPI and 411 ECM
    Feb 2007
    You can enter the number in the Tune Tool and "jump" to that spot. The path in the tree is then apparent.
    You can also designate tables as favorites, making it easier to find them later.
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
    Do as gto_in_nc said...
    use uppercase on the letter (e.g. use B3604 instead of b3604) to find the table itself,
    otherwise lowercase finds all references to that table.
    Oct 2007
    Ahhh. I never tryed using that search feature, didnt know what it was for.
    How do I add one to favs? I see how to delete, but not add.
    11 Silverado
    08 Sierra
    Feb 2007
    Directly under the "Search" button is a blue button with a plus sign in it...
    Oct 2006
    Thanks Jocar, I did not know about the search using capital letters, I was going to ask if there was a way to only search for tables a few weeks back and that has answered my question
    Oct 2007
    Quote Originally Posted by gto_in_nc
    Must only work with an authorized copy. I have them demo one at work still and that didnt work.
    11 Silverado
    08 Sierra
    The demo software and the authorized software are the one and same...
    Can you post a screenshot...
  1. which timing chart?
    By TJWells in forum Gen III V8 Specific
    Last Post: May 22nd, 2008, 12:26 PM
  2. Some PID's values don't fit in the chart...
    By joecar in forum General
    Last Post: March 17th, 2008, 05:00 PM
  3. Chart Inspector
    By killerbee in forum General (Diesel)
    Last Post: August 10th, 2007, 06:42 AM
  4. Do your own Free Dyno Chart?
    By ringram in forum Lounge
    Last Post: July 24th, 2006, 08:25 PM
  5. Chart View Question
    By TAQuickness in forum General
    Last Post: March 9th, 2006, 07:15 AM
