If the car is going to run in SD, then you need to dial in the VE table. The only way you could potentially get away with leaving it stock is on a bolt-ons only car running closed loop speed density. The fuel trims (once learned) would keep part throttle in check and you'd have to dial in WOT through PE. But, it's more than likely that commanded AFR wouldn't match watch the WB reports.
GM.DYNAIR is under 'Air' in the System drop down menu.
