I had the speedometer isssue after installing 7.51. Reducing the number of pids selected cured it.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Good to know!Originally Posted by jfpilla
I guess it did start with the later versions.
Seems to matter not what one sets the VVS values to, and the car speedo reads fine.
PowrMax Performance
100 mm PowrMAF
Yes i noticed that the pid count would peg at 25 and it would stay there.Originally Posted by jfpilla
I checked to see what mode I was logging at.Its when I reduced the number of pids below 24 it came right.
It shouldn't be like that.
Its good to know its not only happening to me.
I went back as I said to an earlier version and will wait for a stable release.
May be I'll retry in case its been fixed.
Thanks for clarifying.
856RWHP 408 Supercharged LS1 Holden Commodore.
Sometimes when I am working on a tune with tune and log open and I apply the filter or hide cell count buttons...the whole log vanishes.
I have to open it again and the filters etc have been applied.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
