Results 1 to 10 of 15
Thread: Issues with 7.51
    Member VT LS1 NZ's Avatar
    Question Issues with 7.51
    Any one else having issues with 7.51.
    *Everytime I go to start the car while logging my speedo jumps to about 45 km then when it starts it stays at 243km .
    *Also I get a bogus DTC P0000 come up.
    If I look at it via V2 its not there but on the laptop it is.
    Ive downloaded and reinstalled in fact Ive used a different laptop.
    No problems if I go back to V7.42(533)
    *Also did anyone get the maps to Automatically load using *.mls
    856RWHP 408 Supercharged LS1 Holden Commodore.
    Oct 2006
    Quote Originally Posted by VT LS1 NZ
    Don't have a issue with Scan Tool that I have seen , but do get the False P0000 codes .
    I had the 7.5.1 build (21) and it worked great , so did not think twice about updating to 7.5.1 build (24) .
    joecar answered me with in a post with the topic "Reset DTCs" have a look .
    http://forum.efilive.com/showthread.php?t=6654
    2006 Trailblazer
    May 2007
    are you on about the actual car speedo? If so its a common problem on the UK Monaros on both ls1 and ls2's - seems a problem with the unit which can be, after much arguing, changed on warranty.
    I've been sat still doing 220mph. It appears a few restarts cures it and the problem doesnt appear for months, very random and rare.
    OF course you can ignore that if you are on about te scan tool reporting incorrect speed
    Quote Originally Posted by stigmundfreud
    No its the Scan tool but thanks for your input.The scan tool speedo will jump to 45km while cranking then once started jumps to a high value .
    Normally I'm able to work most things out before posting.
    It happening on two laptops using the last two releases.
    Ive prove it to EFILive_Scan.exe & obdiiV7.dll files.
    Ive gone back to 7.4
    I'm not able to get the *.mls map-autoload thingo to work...
    Oct 2003
    I have the 36-38 MPH speedo problem with LS1 OS.
    PowrMax Performance
    100 mm PowrMAF
    Jan 2007
    I get the P0000 codes also.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Quote Originally Posted by hquick
    Paul's on it: showthread.php?p=58313#post58313
    Jan 2007
    Yeah...found that thread. Thanks Joe.
    Howard
    DUCT TAPE.
    Oct 2005
    Any fix for this yet as it has my airbags disabled? Don't even have any SI Sensors on my truck.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
  1. What have the issues been with LMM'S?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 03:51 AM
  4. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  5. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
