Results 1 to 6 of 6
Thread: Injectors that come w/ L76 intake (from SDPC)......
    Oct 2007
    Default Injectors that come w/ L76 intake (from SDPC)......
    What size are they??? need to rescale the IFR table...
    THANKS
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Oct 2003
    We are told they are 40# and the same as LS7/3. If you look at the IFR for a LS7 it starts @ 41.7 but with strange Manvac so I use this with good results:
    LABELS Injector Flow Rate (Lbs/Hour)
    Manifold Vacuum PSI {link: GM.MANVAC} Value
    0.0 39.993126
    0.7 40.241145
    1.5 40.489164
    2.2 40.737184
    2.9 40.985203
    3.6 41.233223
    4.4 41.481242
    5.1 41.729261
    5.8 41.977281
    6.5 42.163295
    7.3 42.411315
    8.0 42.659334
    8.7 42.907353
    9.4 43.155373
    10.2 43.341387
    10.9 43.589407
    11.6 43.837426
    PowrMax Performance
    100 mm PowrMAF
    Oct 2006
    Thanks, good info
    Lifetime Member jfpilla's Avatar
    Bruce,
    I get a slightly different result. Not enough to worry about.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Oct 2003
    Joe,
    Agreed.
    The IFR table from the stock LS7 does not escalate like we are used to which is why I started a bit lower.
    Of note is that these injectors perform MUCH better than the SVOs we had used previously. I am told that the SVO spray pattern shoots on the floor of the head where the GMs cone pattern hits the back of the valve as intended.
    This results include no black puff when on the gas, much better hot starts, idle plus a few more mpg. Also these new injectors seem to support more hp.
    FAST sells a 50# of this style.
    PowrMax Performance
    100 mm PowrMAF
    http://forums.corvetteforum.com/show....php?t=1674178
    I got the information a while back. It's from an HP tuners file.
    My LS7 with a Vram and Amer.RacingHeaders @ 6700rpms logs 90% duty cycle. It seems they won't support much more power.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. Intake heater
    By Jetmech in forum Duramax LB7
    Last Post: October 21st, 2009, 03:37 PM
  2. Mercruiser Marine intake injectors
    By onegonewild in forum Vortec V6/V8 Specific
    Last Post: July 22nd, 2008, 11:21 PM
  3. Small Injectors/LS6 Intake
    By RevGTO in forum Gen III V8 Specific
    Last Post: April 23rd, 2007, 01:17 AM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
