Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: MAF Calibration (No Spreadsheets!)
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Default MAF Calibration (No Spreadsheets!)
    It was suggested on here but I had to try it for myself. I am not to up on worksheets anymore and wanted something that was pretty easy to use. I used a custom MAP/Histogram that is based on MAF Frequency and AFR(posted in the other thread. The tables are setup so the difference from commanded and actual is displayed in a percentage just the same as LTFT/Wideband. I plotted the VE table just the same as I would if I was tuning for VE, but instead used the % error from the MAF table and after two passes was done. The ability to make our own custom MAP's is great and no more excel!!! Not to mention the guy is tickled pink now with his car.
    Default Re: MAF Calibration (No Spreadsheets!)
    Quote Originally Posted by black02ss
    That is too awesome! I need some cash to buy EFILive! :P
    Aaron
    '03 Z06 Corvette - The normal stuff...
    EFI-101, EFI Advanced, EFILive-101
    EFI University Evangelist
    Jan 2004
    Once you switch, you will have wished you would have done it sooner. I know I was.
    Oct 2003
    Very Cool! 8) :lol:
    Did you create a PID for % error - I can't find one??
    Can you post the actual steps you used to create the map in EFILive - uhh...a method for the 'tards, like me?
    ( yes, I know that's not pol correct :P )
    Apr 2005
    i would like to see this as well.
    Jan 2004
    Here is the MAF % Error MAP that I used. This is for my LM1 using the Tech Edge BEN. Again, this works awsome on my car. Just copy and paste with a factor back to the B5001 Table. You guys need anything else, let me know.
    Jun 2006
    Quote Originally Posted by Black02SS
    You're the shit
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    9375 Hz MAF map for PLX Wideband O2.
    8)
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Sep 2003
    If your MAF table goes to 12000 like mine, use this map -
    12000 Hz MAF map for PLX Wideband O2.
    8)
    Sep 2003
    By the way kids, this calibration method works extremely well.
    Step by step:
    0. Assuming a calibrated VE using speed density mode and "AutoVE"...
    1. Put the tune in closed loop and all normal PE, etc.
    2. Disable LTFT {B3801} and STFT idle trims {B4108}.
    3. Log a bunch of data - normal driving, wide open (to hit the high Hz, do some bonzai 4th gear 100+ mph runs :wink.
    4. Save the log file.
    5. Filter the throttle transients out using the BEN filter.
    6. Copy and paste the MAF map as a factor into your MAF table in the tune.
    7. Repeat steps 3 through 6 and you'll have the MAF dialed.
    My MAF is dialed in to within 1% from 2375 Hz to 11k+.
    Thanks black02ss; nice work! 8)
  1. odd Calibration
    By CalEditor in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 05:38 AM
  2. 02 LC1 calibration using V2
    By waterbug1999 in forum FlashScan V2
    Last Post: May 2nd, 2009, 10:14 AM
  3. Help with MAF calibration
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2008, 08:37 AM
  4. V2 A/D Calibration - FAQ
    By Blacky in forum FlashScan V2
    Last Post: March 10th, 2007, 10:57 AM
  5. MAF calibration?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2005, 01:22 PM
