would increasing the filter tables speed up the fueling response in the PE settings???(i'm olsd)...
since the airflow increasing in PE is most likely over the 150 grams/sec,could raising the filter closer to 1.0 smooth out the commanded vs actual afr???
i know,a complete off the wall question but charge temperature blending has me thinking this setting would be better suited for changing if i had an iat sensor that was instantaneous reporting...
or just bias everything more towards ect all the time...
