Why is there not an LBZ Auto .pmm file?
2006 GMC 2500HD cc/sb 4X4 SLT LBZ
The Auto v's Manual, just loads an extra *.pmm file and different PID selection.Originally Posted by XLR8NSS
Look in Options.ini and you'll see:
E38, Manual, E38-M.pmm, PSL_LS2-M, PCU
E38, Auto, E38-M.pmm&T43-A.pmm, PSL_LS2-A, PCU
That means E38 Manual requires only the E38-M.pmm file and will use the PID Selection List (PSL) PSL_LS2-M further down in the file.
And the E38 Auto requires BOTH the E38-M.pmm and T43-A.pmm files and will use the PID Selection List (PSL) PSL_LS2-A further down in the file.
If you have an Auto but only want to log the engine PIDs and no Trans PIDs you can select "E38 Manual". Same goes for all other auto v's manual selections.
I just haven't typed in the Allison PIDs yet - hope to get them done this weekend.Originally Posted by markap81
I am getting an error when trying to log in pass through mode. I dont see anything about the hapi program in the system tray. is this something i am doing wrong? also is there a way to add pids?
update the v2 now says passthru active but when i go to scan tool it generates an error report
EFILive_Hapi is only required when using the EFILive_Explorer applicaiton. Hapi is not required when using the V7 Scan and Tune Tool software.Originally Posted by carcrafter22
In fact Hapi MUST NOT be running when using the V7 Scan and Tune Tool software because Hapi hold a connection open to FlashSCan which will prevent the Scan and Tune software from connecting to FlashScan.
As for adding PIDs, you can only add PIDs that we have defined so far, the PIDs defined so far are listed in the *.txt files in the Pid Descriptions folder. Read the Readme.txt file in that folder for more info.
The PIDs currently available are only about 20% of what is available in total. We will add in the rest once everything is working properly.
Can you save the error report and email it to me at paul@efilive.comOriginally Posted by carcrafter22
sorry I wasnt being clear. I made sure that the happi program wasnt running and still couldnt get the scan tool to run in pass through mode. I will get a copyy of the error and send it to you paul.
......is anyone else here not able to flash the lbz controller?
Just for the record , everyone else probably knows this already .
2 things to watch for with the SD cards :
1. Make sure to "format as FAT32" .
2. Make sure card is not "write protected" , small tab on side of SD card that moves up and down .
BBl works great so far . :-)
2006 Trailblazer
There have been a afew problems with CAN based controllers (LBZ included). Hopefully a new update will be availabel before Sat to fix them.Originally Posted by LBZ_GMC
