Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 136
Thread: BB Logging beta version is now available
  1. #11
    Quote Originally Posted by Garry
    Got a "please select connected device" error popup on this, selected "Flashscan V2" again, got an error message with $(somenumber), selected Flashscan again, then it would format the flash ... After this, I was not able to get the previous behavior ...
    Turn on tracing in EFILive_Hapi, then make it happen again (if you can) and save the trace. To turn on tracing right click on the EFILive_Hapi icon in the system tray and select Show. Then select the Trace->Settings window and check the Enable diagnostic tracing option and increase the Size option to, say 1000 lines. To save the trace, select the Trace window and click onthe [Save] button.
  2. #12
    Here's some splash screen bitmaps to play with...
  3. #13
    Oct 2005
    Are you aware that these are all 24BPP bitmaps ?!
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  4. #14
    Oct 2003
    Default V2 BB Logging
    How do we togle between Imperial and Metric in the PID Config.? Do not see how to play pack recorded data? Can the saved log file be played back on the PC? In the CAN Pids I see no PID for Knock Retard with the E38?
    08 Z06
  5. #15
    Jan 2005
    Paul & Ross - Great work again! I really appreciate the sacrifices yall have made to bring this to us.
    For some early feed back:
    After following the scan and tune upgrade process, when launching either the scan or tune tool, I get a "publisher could not be verified" warning from windoze. Must uncheck the reminder box to resume normal behaivor
    Sent you a PM about the firmware tutorial.
    I cannot open the splash screen zip file in post 12. Can you post the file on the website for downloading?
    As Garry pointed out, Firmware 68 is in the V7 directory
    In the readme file, yes I was wondering - thanks for the clarification.
    Otherwise, everything went smooth and checks out great. I will give BBL a thourough thrashing mid-next week!
  6. #16
    Jan 2005
    I was installing a new splashscreen (very cool btw...) and managed to shut down V2
    From the hapi:
    Select image
    click install image
    mouse cursor changes to an hour glass
    While the cursor is still an hour glass, from V2, press F4
    I've been able to duplicate this twice.
    When copying files in EFILive Explorer, a "yes" and "no" "to all" feature would be nice. While jacking with the splash screens, I managed to loose about 15% of the data in the config files. For now, I can format/initialize and copy all.
  7. #17
    Quote Originally Posted by Lennart
    Yes :oops: - EFILive_Explorer automatically converts them to a bitdepth of 1.
  8. #18
    Quote Originally Posted by 02Z06
    There is no option to toggle - but when it is added (very soon) it will allow you to toggle between "metric" (the default) and "custom" (which most people will have setup as Imperial) as specified in the Options.ini file.
    There is no option to play back data yet, but it will be added.
    The BB log files can be copied back to the PC and opened with the V7 software - they are just plain EFILive log files.
    More PIDs will be added over the next few weeks. The ones that are there now are just the ones we were/are using to test with.
  9. #19
    Quote Originally Posted by TAQuickness
    I get the same thing on my XP box - not sure why yet...
    Attached.
    There should be another update posted before then.
    Attached Images Attached Images
  10. #20
    From the hapi:
    Select image
    click install image
    Using the keypad while file transfers are in progress has not been extensively tested. There are some issues that need to be looked at. The solution will most likely be the keypad will be disabled (and the screen will display "data transfer in progress") while files are being copied.
    I will add a "yes to all" and "no to all" option. It bugs me too.
  1. EFILive Version 8 (Black Box Logging) is now available
    By Blacky in forum Do you want to be a Beta Tester?
    Last Post: June 21st, 2009, 11:23 AM
  2. PID list in final Beta and RTM/RTW version?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: October 7th, 2008, 07:55 AM
