Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 60
Thread: Post your "Splash Screen" images
  1. #41
    Quote Originally Posted by odd boy View Post
    how to restore them?
    The files in the [Config] tab page in EFILive Explorer can all be re-copied from the PC to FlashScan at any time.
    To completely reset the [Config] file system follow these instructions:
    1. Plug FlashScan into the PC.
    2. Start EFILive Explorer.
    3. Select the [Config] tab page.
      If you have made modifications to Options.txt file, then drag it from the bottom pane to the top pane. That will save a copy of the modified version to your PC.
      If you have not made any modifications to the Options.txt file then don't worry about saving it.
    4. Click on the [Format] button to format the Config file system.
    5. Highlight all the*.pmm files and the Options.txt file in the top pane and drag them down to the (now empty) pane at the bottom.
  2. #42
    Apr 2008
    I cant read how much I have!!! it says error $0026
    Regards,
    Odd Boy
  3. #43
    Apr 2008
    and if I try to refresh it it says $0182
    Regards,
    Odd Boy
  4. #44
    Error $0182 is F_ERR_NOTFORMATTED, (File system error: 2)
    I highly recommend formatting the Config file system on the FlashScan device.
  5. #45
    Apr 2008
    I cant read how much space I have!!! it says error $0026
    Regards,
    Odd Boy
  6. #46
    Is that after you have tried formatting it?
  7. #47
    Apr 2008
    no, I am afried of the format??
    Regards,
    Odd Boy
  8. #48
    If EFILive_Explorer can't read the Config file system then you MUST format it (it only takes about 15 seconds). There is nothing stored in the Config file system that cannot be easily copied back in, in around 1-2 minutes. In fact, after you format it you MUST copy all the *.pmm files and Options.ini file to FlashScan. That's the way its designed to work.
    I presume you have not made any modifications to Options.txt. If you have see my previous post about saving it first.
  9. #49
    Apr 2008
    I will do it tonight and get back to u.
    Regards,
    Odd Boy
  10. #50
    Nov 2006
    Bump
    I'd like too see some more splash screen images.
    LC-1 WBO2
  1. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  2. Replies: 0
    Last Post: October 8th, 2008, 01:01 AM
  3. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  4. Should we make a sticky and post in our "custom scripts
    By wait4me in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 05:02 PM
  5. "screen size inadequate" msg
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2006, 09:40 AM
