Results 1 to 7 of 7
Thread: merging log files
    Member tazinhawaii's Avatar
    Apr 2006
    Default merging log files
    So, I drive to work and back logging each way... Is there any way to merge the two log files into one so I can auto VE tune 20 minutes worth of data vice picking one of my 10 minute trips? I can't seem to find any way. And if there isn't any way of doing this, can I recommend incorporating a feature like this into the next version of EFI Live.
    Derrick
    1969 Camaro, LS3, 4L80E, Dana 60 rear, Air Ride, 19 and 20" wheels, Baer Brakes, and a lot more.
    2008 Charger SRT-8 Super Bee, Exhaust and Cold Air kit (Wife's car)
    2007 Yukon XL Denali, Family Hauler
    http://s330.photobucket.com/albums/l...i/69%20Camaro/
    Jan 2007
    PM 5.7 Ute
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jun 2005
    If it's a matter of merging AutoVE BEN tables, you can do it in Excel.
    Just copy/paste log 1 & log 2 cell counts in the first two blue boxes. Then, copy/paste log 1 & log 2 BEN averages into the next two blue boxes. Just above the last box, you can adjust the settings.
    • Do you want to apply 100%, 75%, 50%, etc. of the correction? Type in what you want...
    • Do you want to ignore cells you have insufficient data for? Type in the minimum number of cells needed for data to be valid...
    Jun 2005
    Woooohoooo....sticky!
    Feb 2007
    How would this work logging both banks at the same time to get average VE?
    Jun 2005
    Personally, I would take the safe approach of tuning for the leaner bank since they typically aren't 100% equal.
    Member 427's Avatar
    Dec 2007
    Cool
    Nice work guy's
    Nick--
  1. '09 E85 6.2L files ?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: November 29th, 2008, 10:32 AM
  2. Merging cax files
    By joecar in forum CAX Files
    Last Post: September 28th, 2008, 08:01 AM
  3. Merging Log Files?
    By Cougar281 in forum General
    Last Post: July 7th, 2008, 01:27 PM
  4. MAP files help
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 12:33 PM
