I remember Dirk Diggler (aka HumpinSS) discussing his FJO and analog voltage. GMPX said the max. input AD voltage was 4.8 volts - which I verified in the docs section ( sometimes my memory deceives me - it's tricky like that!!).
I've noticed the PLX outputs 0-5 volts and these are listed in the PLX PIDs.
My FJO can output 0-5 volts, or I can customize a 0-4.8 volt - which will require a custom set of PIDs (AFR and BEN). Can I use the PLX or is it Better to use the 0-4.8v output???
TIA.
joel
