I have downloaded and extracted everything properly (I think) but when I go to run the EFILive explorer and click on Flashscan V2 it says its not connected and I have tried in and out of dead poll mode????
Help please
Help please
2006 CHEVROLET 2500HD LBZ CCSB, SUMMIT WHITE
Make sure the Scan and Tune tools are not running and try again. If that is not the problem, start the EFILive_Explorer program and click on the [FlashScan] button to attempt to connect to FlashScan, then...
1. Show the EFILive_Hapi program (i.e. right click on the FlashScan icon in the system tray at the end of the Windows Task bar, and select Show).
2. Goto the Connections->Settings page and make sure FlashScan is checked and AutoCal is unchecked, (unless you are beta testing AutoCal as well).
3. Goto the Trace->Settings page and check both check boxes and set Size to 10000.
4. Goto the Trace page and click [Clear].
5. Goto the Settings page and click on the [Status] button. You should see two green ticks under USB and CNX.
If not, go back to the Trace page and click [Save]. That will save the entire trace - not just tha last 20 lines that are displayed on that page.
Check the error numbers in that file with the error descriptions here:
http://forum.efilive.com/showthread.php?t=6732
If it is still not clear what is causing the problem, send the file to me at paul@efilive.com
Note: When you have done all this, uncheck the checkboxes in step 3 to turn off tracing.
I must have a problem with something else, I dont have a flashscan icon in the task bar and when I go to the hapi file and click on it to open it will show on the task bar for a moment and go away
See post #44 in this thread:
http://forum.efilive.com/showthread.php?t=6724&page=5
