Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 100mm LPE MAF
    Lifetime Member jfpilla's Avatar
    Talking 100mm LPE MAF
    http://forums.corvetteforum.com/show....php?t=1705010
    I just installed a 100mm LPE MAF.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Nice joe!
    where is the MAF Hrtz vs. rpm different from the stock MAF? How much resolution did you pick up.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Howard,
    I'm only comfortable up to 4125hz. After that it goes to 0 ltft's. I need to get on a long clear road to get enough information.
    At 6100 rpms map went from 94 to 98 kpa and the maf g/s line has no jagged spikes at all. It's smooth. I returned most A/F tables to stock, except for TCracker and that makes sense since I have a 3600 stall and an A4. I had to create DAF and VE(VE only close until I get motivated).
    Joe
    Here is change history.
    LS7 specific
    {B0104} Cylinder Volume, changed from "45.516408" to "53.456163"
    {B3604} Commanded Fuel When Cranking. STK LS7
    {B3640} Clear Flood Enable, changed from "80" to "85". STK LS7
    {B3702} Injection Timing. STK LS7
    {B4001} Injector Flow Rate. STK LS7
    {B4003} Minimum Injector Pulse Width. STK LS7
    {B4005} Small Pulse Adjust. STK LS7
    {B4004} Default Minimum Pulse Width. STK LS7
    {B3701} Injector Pulse Width Voltage Adjustment STK LS7
    {B6001} Spark Dwell Time. STK LS7
    {B0304} Baro Offset Factor STK LS7
    {B5909} Spark Timing when Cranking STK LS7
    {B5944} Spark IAT vs ECT Multiplier. STK LS7
    {B5933} Base Spark in Park/Neutral STK LS7
    {B5932} Base Spark in Gear STK LS7
    {B4205} Closed Loop Temp Enable, STK LS7
    {B5914} Spark Low-Octane Table, copy of high octane
    {B5913} Spark High-Octane Table. Modified LS7
    {B4603} Desired Idle Speeds, Modified LS7
    {B5910} Spark ECT Table. Modified.LS7
    {B5911} Spark IAT Table. Modified LS7
    {B5956} Coolant Temp Spark Multiplier Modified LS7
    {B5001} MAF Sensor Calibration Modified LS7
    {B4307} Desired Airflow, created
    {B4343} Startup Friction Airflow Correction created from LS1/Z06
    {B4309} Throttle Cracker Airflow in Gear, created from Z06/LS1
    {B0101} Main VE Table. created from LS1
    {B3618} PE Modifier Based on RPM, created
    {B5936} Idle Underspeed Error, modified ls1
    {B5901} Catalytic Converter Light-off modified ls1
    {B5912} Engine Protection Mode Timing modified ls1
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    I missed the resolution answer.
    The LS1 Maf table goes from 1500 to 12000. The LS7 from 1000 to 12200. I won't use the outside values, so nothing lost. But the LS1 values are 125hz apart vs 150 for the LS7. By filling in values I picked up some resolution. That was a lot of work and I'm not done. I think I'm close, though.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Nov 2006
    so did you have to change the reluctor wheel,
    or does the LS7 have the 24X from stock?
    if you changed it, did you have to completely disassemble the engine?
    Quote Originally Posted by mr.prick
    It's been converted to a wet sump and a 24x C5 reluctor wheel. Skoggins Dickey will convert it for a small upcharge and warranty it. Theres no point in converting it yourself.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Nov 2006
    Quote Originally Posted by jfpilla
    It's been converted to a wet sump and a 24x C5 reluctor wheel. Skoggins Dickey will covert it for a small upcharge and warranty it. Theres no point in coverting it yourself.
    ahhh
    Oct 2003
    Despite opinions to the contrary, there is just NO replacement for displacement.
    PowrMax Performance
    100 mm PowrMAF
    Quote Originally Posted by Bruce Melton
    Except for boost!
    1-954-703-5560
    Or boosted displacement! lol
  1. Dyno with 100mm
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2008, 03:41 AM
