Results 1 to 10 of 11
Thread: V2 Stuck in dead poll
    Jan 2006
    Default V2 Stuck in dead poll
    It was not like this last night after the update. Now today after the update for BBL my v2 box is flashing lights likes it is in dead poll mode but its not. I never plugged into a car yesterday just my laptop. No matter what I do the box stays flashing like in dead poll mode. If you try to acess it in dead poll mode it says hoold down control even though you are. It wont read a car or connect to my laptop. Just plugging it into a car it will flash the dead poll lights with the ignition still off.
    I need help ASAP! I have a customers car here that I have to have done by tomorrow morning.
    Hi Lorenz,
    Dead-poll mode will be automatically entered if FlashScan detects
    corrupt or damaged firmware. You should try, reprogramming the unit
    again using the EFILive_Explorer program's firmware programming option.
    With beta software there is always the possibility that it could fail.
    That's the whole point of beta testing.
    A new beta update will be released in the next day or two to address
    many of the issues that have been raised by the beta testers so far.
    I can't guarantee that the new update will fix your problem but right now
    there is no other option but to wait for the update.
    Jan 2006
    I can't reprogram it. It just flashes "like" its in dead poll. I tried to re-flash the firmware but tit will said Im not in dead poll mode. The box wasnt like this after the update. It did this the next day when I plugged back into it.
    When you say "like deadpoll", is it flashing the two orange LEDs alternately or are the LEDs flashing in a different pattern?
    The POST (Power On Self Test) routines display error messages by flashing the LEDs in certain patterns, the patterns are as per the image attached.
    Oct 2006
    Can someone put the new Error code list and LED error codes in one place ?
    Like pin to V2 section .
    2006 Trailblazer
    Quote Originally Posted by tunedbyGM
    Done, they are in the V2 beta section for now.
    The error numbers and POST LED patterns are only appropriate for the new V2.5 firmware. Not for the current V2.4 firmware.
    Jan 2006
    The two orange LEDs are alternately flashing.
    If the new 2.5.x bootblock has been installed, you won't be able to use the "old" FlashSCan programming software. I.e. the one on the Windows Start menu.
    You can only use EFILive_Explorer's Firmware programming option. When you try to reflash the firmware using EFIlive_Explorer, what error message do you get?
    Jan 2006
    I can flash the firmware but the v2 will lock up if you push any buttons. If you unplug the v2 after flashing it will go back to dead poll mode.
    Quote Originally Posted by minytrker
    Send me your V2 serial number and your shipping address and phone (to paul@efilive.com) I'll send a replacement unit to try.
  1. This is total BS - stuck in dead poll mode.
    By Mr. P. in forum FlashScan V2
    Last Post: September 9th, 2009, 09:35 AM
  2. stuck in dead poll mode
    By stacks04 in forum FlashScan V2 BB Logging
    Last Post: June 26th, 2008, 03:52 AM
  3. Dead Poll
    By sfcjones in forum Black Box Logging
    Last Post: March 26th, 2008, 01:10 PM
  4. FS not communicating in dead poll
    By Big Block in forum Black Box Logging
    Last Post: January 7th, 2008, 12:24 PM
  5. PCM in Dead Poll State?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 6th, 2005, 11:19 AM
