Results 1 to 8 of 8
Thread: 2 BAR - LS2 - Kpa Correct MAPv-Not
    Sep 2003
    Default 2 BAR - LS2 - Kpa Correct MAPv-Not
    Hello all, I am working with a 2006 SSR 6.0l Supercharged. I upgraded the OS from 12612557 to 02612557 I set the MAP sensor scaling as follows:
    Used to scale the MAP sensor voltage output into a kPa/psi value.
    1bar sensors are typically - 94.429688
    2bar sensors are typically - 188.000 <<- this is my setting
    See Also:
    - {B2102} MAP Sensor Scaler 2
    And for B2102...
    2nd Offset value applied to the MAP sensor value.
    This value would typically be {B2101} "MAP Sensor Scaler" divided by 3.
    Eg -
    94.429688 / 3 = 31.476563
    or
    188.000 / 3 = 62.667 <<- again this is my setting.
    Problem is that if I look at the MAP voltage with the scantool it reads 4.5v KOEO. If I check the voltage on the sensor it reads 2.5v KOEO.
    The Kpa output seems to be ok I was just wondering about the voltage PID.
    Anyone have any thoughts on this?
    Regards,
    Scott
    Scott Brown
    Scott, the scalers convert the voltage to a real kPa value.
    The voltage as you see is not right at KOEO, yet, you are saying the kPa reading is correct?
    Sep 2003
    Hello Ross, the scantool says 4.5v KOEO and 97Kpa, with a voltmeter attached to the MAP sensor it reads 2.45v KOEO. During engine operation and under boost the scantool reports 5.0v but the Kpa reading increase as I would assume they would based upon engine speed.
    If I look at a log from about 50% TP to WOT I see the following:
    TP 50% 75% 100% 100%
    MAPv 4.1 4.6 5.0 5.0
    MAP 85 109 135 147
    RPM 3706 3780 3750 4202
    Thanks for the help.
    Regards,
    Scott Brown
    Scott, I can only assume now there must be yet another scaler for the Vout PID. I'll check it out.
    Sep 2003
    Ok let me know what you find.
    Scott Brown
    Which PID was it? SAE.MAP or GM.MAP?
    Sep 2003
    Hello Ross, the voltage PID is GM.MAP and the value PID is SAE.MAP
    I hope this helps,
    Regards,
    Scott Brown
    Helps to confuse
  1. How to correct WOT for each gear?
    By PRAY in forum Gen III V8 Specific
    Last Post: June 9th, 2008, 09:00 AM
  2. Is this map correct?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:22 PM
  3. How can I tell if I got the correct cable and all...
    By Loudmouth LS1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 5th, 2007, 01:58 AM
  4. WHat is the correct timing?
    By Mike :) in forum General
    Last Post: June 15th, 2006, 02:42 PM
