Hello all, I am working with a 2006 SSR 6.0l Supercharged. I upgraded the OS from 12612557 to 02612557 I set the MAP sensor scaling as follows:
Used to scale the MAP sensor voltage output into a kPa/psi value.
1bar sensors are typically - 94.429688
2bar sensors are typically - 188.000 <<- this is my setting
See Also:
- {B2102} MAP Sensor Scaler 2
And for B2102...
2nd Offset value applied to the MAP sensor value.
This value would typically be {B2101} "MAP Sensor Scaler" divided by 3.
Eg -
94.429688 / 3 = 31.476563
or
188.000 / 3 = 62.667 <<- again this is my setting.
Problem is that if I look at the MAP voltage with the scantool it reads 4.5v KOEO. If I check the voltage on the sensor it reads 2.5v KOEO.
The Kpa output seems to be ok I was just wondering about the voltage PID.
Anyone have any thoughts on this?
Regards,
Scott
