Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: '06 E40 PCM locked
    Nov 2007
    Default '06 E40 PCM locked
    I swapped a LH6 5.3L into my 1998 Jeep Wrangler. I had it mail order tuned. The tuner used LS1 Edit. I just bought EFI Live to do some tuning myself but it is telling me the PCM is locked.
    The original tuner said he could unlock it for me but that might wipe out his original tune? Is that correct? I was hoping he could unlock it and that i would still be able to make modifications to his tune. Thanks in advance.
    Sep 2003
    I know that he can re-write the cal but before he does he needs to check the unlock E40 ECM option before writing. He can do this with his last saved tune file leaving you with a copy of where he left off.
    Regards,
    Scott Brown
    If you have a recent version of EFILive, when you try to read the ECM select the option "Use Alt Key", it might be able to read it then.
    Nov 2007
    Thanks guys. I have the latest version V7.4.2 so i will try the Use Alt Key option.
    Nov 2007
    Uder the PCM security option, it says the ECM is secured with a custom key. Also, i don't see a " Use Alt Key" option. I tried entering the $ffff but that didn't work either. Any other options for unlocking it?
    Another newb question. It is throwing two codes for the transmission. Where do i go to deselect them from being monitored? It is reading a code for a part that my new trans doesn't have. Thank you. Rick
    It's not in the security section, it's a tick box on the read/write box that pops up.
    Nov 2007
    i am very new to this.
    so, on my tuning version i click on the "Read calibration data from PCM" ? is that correct? then i select my controller from the list. after i hit start an error box comes up saying the PCM is locked. there is box to enter "Key" and a small box to check "use high speed". so, am i in the wrong area. Thank you.
    Jan 2004
    That is the right box you are describing. Under the box to enter the key there should be two check boxes like in the attatchment below.
    Nov 2007
    I have the E40 controller not the E38. The E40 option doesn't show me the "use alt key" options. Hmm, not sure why mine doesn't show that tick box.
    i have V 7.4.2 (build 657)
    Jan 2004
    Yeah, I know you have the E40 but, mine shows it with any of the controllers selected. I was just using that pic as an example of where the alt key box was at.
    I have 7.5.1 build 26.
  1. I Locked PCM but now have new V2
    Last Post: September 16th, 2008, 01:13 PM
  2. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  3. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  4. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
