Help,
I have read the docs and tried many things. Just can't seam to make it work.
I am trying to scan a vintage Uni stream.
Mode 1 is commanded by a 10k resistor.
The stream has a 3 byte header $F0 $95 $ 01 followed by a 63 byte packet.
EFILIVE will pickup the stream and sync when I select Listen to chatter, but I can't seen to sync when I try and build a mode 1 macro. I have tried to change the timing settings but still no success.
I am trying to listen for the header (3 bytes) then capture the following 63 bytes +1.
Thought I would ask if anyone has any suggestions on the 8192 UNI stream.
Thanks for any help-
John
