Just a general question to place on the floor for discussion-
Situation- Customer had an issue using brand x hand held programmer.
My guess would be a low voltage situation part way through programming causing programming to fail. On the older PCMs this would be terminal.
I was told the bootloader on an E38 can not be damaged by programming.
Oddly enough the E38 was a no start but would still communicate with a tech 2. I tried to reflash with a tech 2 and sps but the ECM would not enter Hi speed mode. Per customer request I spoke with brand X tech support.
Nice guy, I was told no matter what I should be able to fix any of their programming issues with a tech 2 and sps. I had to remove the ECM and send back to brand x and they reflashed back to stock. I was told they use GM sps to fix flash issues but I have been unable to on several ECM's.
I have seen this situation using SPS and had to replace the ECM to get the vehicle running again.
Any tricks anyone is willing to share on how to repair a failed flash attempt?
The ECM's are still online but will not reprogram using factory equipment.
Will FlashScan repair this situation? If so will it require a license to restore the stock flash? Any way just hoping for a few comments from anyone on this situation.
Thanks,
John
