Results 1 to 6 of 6
Thread: Unable to log
    Sep 2007
    Default Unable to log
    Running V2 with the latest updates on a Windows 32 bit Vista laptop. I'm trying to log data on a 2000 Chevy Silverado 5.3L auto 2WD, and can't do it. I can do everything else, pull PIDs, even test the O2 sensors. I can connect to the truck. As soon as I tell it to start scanning, it locks up. What am I doing wrong here, or is this the same problem I've been reading about? I've read a lot of posts on logging problems but got the impression that this was only with black box logging, and I'm trying to do this with the laptop plugged in. Everything else is working fine.
    Jan 2005
    When you say latest updates, do you mean that you have applied the beta updates, or just he latest puplic updates?
    Sep 2007
    Good question. I'll check tonight. I put in the latest updates I could find, but usually do not run with beta updates. My skills with programming suck, so I try to stay away from potential bugpacks. I like to wait till others have blazed the trails along those frontiers. I've got no problems with making major vehicle mods to slap on unusual parts when my wallet allows but playing with bits is just not me.
    Jan 2005
    when you get the chance, click help -> about in the scan and tune tool and post up the versions.
    if you are running the latest public releases, then you might try checking the scan tool properties to verify the PCM selection and cable type are correct.
    Sep 2007
    Excellent. Wasn't able to look at it yesterday, will try today.
    Edit - Here's what it says.
    EFILive_Scan.exe V7.5.1 (Build 24)
    V7.5.1 (Build 24)
    Sep 2007
    I figured out what the problem was, apparently I needed to increase the amount of space for logging. Once I did that everything started working, so long as I used a supplied PID map. When I log into this board from the laptop with EFI Scan on it, I'll modify this post with exactly what was changed.
    If I tried building my own, then as soon as I started logging the gauges showed incorrect values, like idling at 3500RPM at 25MPH. Any ideas what might cause that? If I reloaded the Imperial base PID file everything would report correctly, and the PID file I created was a modification of that file with a few more parameters added. Vehicle was also set up correctly.
    Edit - Under Edit -> Properties -> Logging , I increased Framed (x1000) and this seemed to start allowing me to make log files. I was able to log longer than my laptop battery would last.
  1. E38 unable to program
    By HTMtrSprt in forum E37, E38 & E67 PFI ECM's
    Last Post: April 29th, 2010, 12:35 AM
  2. Unable to flash Custom OS into PCM
    By Robbie The Wrench in forum Gen III V8 Specific
    Last Post: February 23rd, 2009, 03:00 AM
  3. Unable to see GM PIDs
    By Babydeuce in forum General
    Last Post: May 28th, 2008, 10:04 AM
  4. Unable to read DTC's
    By rdaniels in forum FlashScan V2 BB Logging
    Last Post: May 18th, 2008, 05:32 PM
  5. unable to clear dtc's
    By vdawg4 in forum EFILive V4
    Last Post: January 28th, 2008, 03:39 PM
