Still trying to sort out my my starting issues. It will crank and fire, stumble, then stall. Then restarting it will just crank n crank tell I hit the peddle. I have been told this puts the ecm into "flooded" mode and kills fuel. So with that I added 1gps to B4343 as speed demonded suggested a few weeks ago to me. I also removed fuel from my idle areas on the main ve table. I have no fuel added upon restart.
I then logged startup, some idling, revving, a kill then restart(around 17:55). If you guys can, see what might be giving me fits here. If I need another pid, let me know as I'm going to log it on my way to work tomorrow.
Some things I see wrong is my TPS is at .7v, when it should be .50-.55. Will work on that soon as I post this. My speed sensor is still not working. Could use some help on getting that fixed. My idle should have went down to 675rpms, but I never saw it get below 700. Rest I'm not really sure where it should be as I'm still a newb.
