There is a known problem when using passthrough data logging on CAN based controllers and DMA PIDs. Using DMA PIDs will cause data logging to fail.
Workaround: Remove all DMA PIDs from the PID selection.
This will be fixed in the next update - probably before the weekend.
Note: DMA PIDs are not supported in Black Box logging mode either. Support for DMA PIDs will be added in a future beta update.
