Results 1 to 6 of 6
Thread: Checking out tune w/o WBO2?
    Lifetime Member Garry's Avatar
    Jun 2006
    Default Checking out tune w/o WBO2?
    Wondering ... I will be checking into a 98 F-Body next weekend that has some mild mods and had been tuned by some tuner ... car doesn't have a WB, so with most of the experience I have from tuning my car (which has a WB) I'm not really sure how much I can check ... Any suggestions as to which PIDs to logg and what to watch out for (except for the obvious: NBO2 values, knock, ...)
    Tnx!
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Jun 2005
    If it's just bolt-ons, I wouldn't worry too much. Just make sure the timing is jacked up too much over stock and the AFR isn't leaned way out. The earlier models really didn't need a lot more timing - mainly fueling corrections. If that stuff looks ok and the fuel trims aren't way out of whack, it should be fine.
    If you're going to log it, I'd go with these (plus the LTFT pids):
    Jun 2006
    Not really just bolt-ons as far as I understand it ... but as I said, it was already tuned (SpeedInc), so unless they messed up, it shouldn't be too much to need changing ... (it's a 98, so I can play around with it ...)
    Jun 2005
    Quote Originally Posted by Garry
    Well that's a little different. Being tuned by a reputable shop vs. "some tuner" is a little different.
    Jan 2005
    On top of SSpdDmon suggestions, you might take a look at the LTFT's to get an idea of what the PCM is doin for fueling.
    That said, I've seen some pro-tunes with WOT timing in the high 30's and PE AFR in the 10's...
    Nov 2006
    Quote Originally Posted by TAQuickness
    LOL i`ve see that before.
  1. checking wideband accuracy with the narrowband?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2009, 08:59 PM
  2. Checking TC and TF
    By Kurtomac in forum Gen III V8 Specific
    Last Post: February 7th, 2009, 03:16 AM
  3. checking my understanding (2bar and maf)
    By SScarTuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 27th, 2007, 03:25 PM
  4. Newb checking in!
    By Kevin Doe in forum Lounge
    Last Post: October 1st, 2007, 04:28 AM
  5. USB Drivers - Checking
    By Kiwi Ed in forum Tips and tricks
    Last Post: June 30th, 2007, 05:14 PM
