I've fitted a 4l80e to my Patrol with a LS1 turbo and have only got 2nd and reverse. I made the wiring changes as outlined in one of the threads on the forum and have a custom OS that incooperates a 2002 Silverado 6.0l which is 4l80e equiped, I did a trans segment swap. It shows the correct gear in the scan tool from the PNDR sender but the gear the trans is in is 2nd.
P0758, P1860, P0753 codes log which are shift solenoid A and B and torque converter pulse width solenoid. The trans has had a shift improver kit but is still a full auto. I removed the codes to see what the result would be and it still dosent shift out of 2nd but the trans does then reflect that it is shifting gears on the scan tool.
Does anyone know if this could be a result of incorrect wiring on my behalf on the swap or a valve body issue from the shift kit.
Any help appreciated
Joel
