Results 1 to 9 of 9
Thread: What file sysrem is present now??? and more!
    Jul 2004
    Default What file system is present now??? and more!
    Just spent a couple of hours logging and found I couldn't see the logs in the V2. Seems it thought it was supposed to use the SD file system even though there was no SD card present. I can understand, well, barely, that I have to go tell it to use the internal file systen when there is no card present, but no error message when trying to write to a non existant memory card?
    Also I notice while starting to log and pressing F2 to view without logging that the message "Creating log file" still appears but pressing Cancel at the end does not cause the file to be saved!
    Would it be possible to have the F1-F4 keys adjust the brightness of the LEDs while logging. The solid Yellow and flashing Blue LEDs are almost blinding when I'm logging in the car at night.
    Ira
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Quote Originally Posted by Ira
    Ira
    100mph tape will adjust the brightness!
    Dave.
    Senior Member SV8346's Avatar
    Nov 2007
    blue tac works for me
    JWould it be possible to have the F1-F4 keys adjust the brightness of the LEDs while logging. The solid Yellow and flashing Blue LEDs are almost blinding when I'm logging in the car at night.
    Ira
    There is an optionin the next update to disable the LEDs.
    P.S. looking at the other issues you raised.
    Lifetime Member SS2win's Avatar
    Feb 2005
    I'm afraid those LED's are either on or off. tape will fix it for now.
    2001 Camaro SS
    EFILive Custom OS3
    Lifetime Member Garry's Avatar
    Jun 2006
    Well, dimming them would mean doing PWM, which - depending on how much the processor is busy for the imortant stuff - might or might not work ... an ISR with low priority could work, but would probably require a free internal timer on the processor ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Quote Originally Posted by Garry
    Correct, if/when a brightness control is done, Iwould do it using an existing ISR. However, it is not a high priority. What is a priority is the ability to turn the LEDs off for night use. They are too bright for night time use.
    Jul 2004
    I see we can turn them off now, but I want more! I would like them on because after they defaulted to off during the upgrade I thought the communication with the PC had died. Silly me! If I'm in a car at night and forget to turn the lights off before starting logging,I'd like a way to turn them off without stopping logging, possible F1.
    Ira
    Ira
    http://forum.efilive.com/showthread....9746#post59746
  1. 98 s-10 os file
    By haulinit in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: May 20th, 2010, 11:10 AM
  2. LD9/LN2 .tun file
    By Mr. Pute in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: June 4th, 2007, 05:20 AM
  3. Bottle neck? How to determine if present
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 04:30 PM
  4. A Christmas Present for the Majors
    By TAQuickness in forum Lounge
    Last Post: December 25th, 2005, 08:28 AM
