Just spent a couple of hours logging and found I couldn't see the logs in the V2. Seems it thought it was supposed to use the SD file system even though there was no SD card present. I can understand, well, barely, that I have to go tell it to use the internal file systen when there is no card present, but no error message when trying to write to a non existant memory card?
Also I notice while starting to log and pressing F2 to view without logging that the message "Creating log file" still appears but pressing Cancel at the end does not cause the file to be saved!
Would it be possible to have the F1-F4 keys adjust the brightness of the LEDs while logging. The solid Yellow and flashing Blue LEDs are almost blinding when I'm logging in the car at night.
Ira
