FS = Flash Scan , BBL = black box logging
O-k everything sounds good on paper , what about answers for the question of , "Why we are not able to update the FS firmware (not FS BBL firmware) ." ?
I figured out for myself that you can press the "crtl>cancel" for reboot and by passes the locked screen.
Tried updating FS firmware through EFILive Explorer and get error $0023 (I know you are not to use the EFILive Explorer to update the FS firmware just FS BBL firmware just thought I would try it ) .
The "read me" states to put the FS into "dead-poll mode" to do FS firmware update . Then do the FS BBL firmware (different firmware) through the EFILive Explorer program .
Like myself and someone else stated the FS firmware software will not see the V2 FS or the V2 FS will not go into "dead-poll mode" (ctrl button held and inserting USB into port , ctrl button seems to have lost response to being pressed and when you do get the LEDs to start flashing for "dead-poll mode" the software will still not see the FS unit) and will not allow it to be updated (not the BBL firmware through EFILive Explorer) .
The firmware in question is FSProg_V2_4_69.ffw .
The "crtl" button has worked up until last update .
FS firmware no can do , FS BBL firmware can do .
(simplified version) FS hold "crtl" plug USB no work , FS hold "crtl" plug USB , yeah , get flashing orange LEDs , FS software no program , FS programmer no can recognize FS unit .
Not trying to be rude just covering all bases .
