Results 1 to 7 of 7
Thread: Advise required by newbie
    Dec 2007
    Default Advise required by newbie
    Hi All
    I need assistance in acquiring the right equipment. The backround informations is as follows: I am installing a LS1 and 4L60E into a Toyota Landcruiser. I currently have an ECU from a 1998 Camaro, however the motor that I am wanting to run has been purchased from Turnkey Engine Supplies and the exact specs of the motor are unknown. They claim that it is a 390 HP motor.
    I am currently considering getting the EFILive Flashscan V2 and Roadrunner plus the LC1 wideband O2. The immediate questions that I need assistance with is do I stick with the 1998 ECU or do I look for a later model (1999+) ECU.
    Forgive me if this is a silly questions, but I am sure there are going to be many more from me.
    Jan 2007
    99+ ecu.
    Don't even consider the 98!
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Dec 2007
    Anyone else????
    Jan 2005
    I would go with a 99-02 ECU. Lot's more tuning options available for those years.
    Sep 2003
    I.D the motor first. Make sure its an LS1 and not LS2. Or make sure you have the right type of ecm for the motor you have.
    Dec 2007
    Thanks for the reply. The motor is definately an LS1.
    Lifetime Member Doc's Avatar
    Oct 2005
    Your command of fueling with the 98's is going to be very limited at best. I would look for a 99-02 pcm and harness.
    www.efialchemy.com
    www.greatamericancarwar.com
  1. Fuel Trim help needed, please advise
    By kwhiteside in forum Gen III V8 Specific
    Last Post: August 26th, 2009, 06:15 AM
  2. AutoVE Best Power Advise
    By Rusty in forum Gen III V8 Specific
    Last Post: January 19th, 2009, 04:52 PM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
  4. Did I kill PCM; Advise Please
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2006, 11:50 AM
  5. Questions and some advise about custom OSv3
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 10:45 PM
