Results 1 to 3 of 3
Thread: Wideband O2 installation
    Senior Member PSWired's Avatar
    Jan 2005
    Default Wideband O2 installation
    So I picked up an LC-1 last week and need to install it to get my cam dialed in (212/218 in an LQ9). My original plan was to install in place of the passenger narrow band sensor and use the LC-1 simulated NB output to feed the PCM. However, I haven't been able to come up with an old oxygen sensor to get the connector from so I don't have to modify the engine harness. So it looks like I'll be welding in a bung, the question is where. I have dual 3" back to behind the dual in/out muffler and this is an extended cab pickup so the combine point is REALLY far behind the engine. Plus dual 3" magnaflow cats. Where should I install the sensor, is right next to the NB sensor on the passenger side okay?
    1995 GMC Yukon 4WD 4DR
    5.3 "LMG" engine: E85 with AFM
    6L80e 6 speed automatic transmission
    Default Re: Wideband O2 installation
    Quote Originally Posted by PSWired
    Try pre-cat if possible, next to or near the NBO2 is good, that's exaclty where mine is.
    Lifetime Member mistermike's Avatar
    Dec 2003
    www.casperselectronics.com should be able to get you all the plugs, extensions etc. you need. You have to heed the grounding instructions if you're going to do NB sim or expect accurate logging. You can use the original NB's as a heater load or a power resistor of the same value as the heater in the old O2 sensor. Those aluminum case jobs with the 2 mounting tabs are ideal.
    Some people have mentioned error messages with the LC-1 due to the voltage drop during cranking. I slapped together a crude time delay that's good for about 18 seconds or so. It eliminates any chance of error message and allows enough time to purge condensation from the plumbing before it splashes up onto a hot O2. You can change the delay with the capacitor value. 350 uF is just what I had lying around.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
  1. Guts Kit installation
    By SS2win in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 6th, 2015, 01:41 AM
  2. DSP5 Installation help...
    By duramax07tmd in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 27th, 2010, 05:07 PM
  3. Software Installation
    By GHamm in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 19th, 2007, 08:29 AM
  4. Installation Error
    By bsbozzy in forum Lounge
    Last Post: November 21st, 2005, 05:01 PM
  5. PLX M-250 Installation
    By Patches in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2005, 07:43 AM
