Results 1 to 2 of 2
Thread: Log rail pressure as MPa
    Feb 2007
    Default Log rail pressure as MPa
    Before I downloaded the most recent update I was able to go into the configuration folder, open the sae_generic file and change the metric units of PID SAE.FRP_C to kPa to MPa. I can still change it, but when I open the scan tool it doesn't show MPa in the units on the PID list and when the PID is selected as metric it still shows to be logging in PSI in the Data tab. Do I need to make a custom PID or am I doing something wrong now?
    Feb 2007
    Found the problem. I didn't change the units in one spot that I needed to.
  1. LBZ-Odd Rail Pressure Drop
    Last Post: May 7th, 2010, 11:55 AM
  2. Question on a LBZ fuel rail pressure?
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 07:45 AM
  3. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  4. walbro 255 pressure at the rail..........?
    By mr.prick in forum Gen III V8 Specific
    Last Post: August 14th, 2007, 06:43 AM
  5. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
