Results 1 to 10 of 11
Thread: LB7 Oil Pressure logging
    Default LB7 Oil Pressure logging
    Hi All,
    Attached is an updated gm_enhanced file that includes a new DMA PID to log the Oil Pressure on the LB7. Also, the incorrect imperial scaling for the LLY+ Oil Pressure PID has been fixed.
    The new PID's have not been confirmed to be accurate on a vehicle as yet but feel free to download the zip file and provide feedback (LB7 onwers in particular).
    Extract the attached zip in to the directory shown below.
    \Program Files\EFILive\V7\Configuration
    The new LB7 Oil Pressure PID is called - GM.LB7_OILPRES_DMA "LB7 Oil Pressure"
    EDIT:
    If you can't get the attachement, download the file HERE instead.
    Dec 2007
    i down loaded it and un ziped it... but i can not read the file..
    i think i am missing som basic compytore skills
    Can't read it?
    You just need to unzip it in to the directory specified above, or, is the PC saying the file is not valid?
    Dec 2007
    Can't read it?
    invalid or corupted
    Jun 2007
    The zip file tells me to insert the last disk of a multi-volume set and click OK.
    Dec 2007
    Quote Originally Posted by CntrlCalDmax
    i got one disc when i purchased V1 from guy trip
    Jun 2007
    I downloaded again and it errors with:
    Windows cannot open the folder.
    The compressed (zipped) folder C:\users\........\gm_enhanced.zip is invalid.
    Feb 2007
    I get the same message.
    I just put a download link in the first post to download the file directly, not from the forum as an attachment. See how that goes for you all.
    Dec 2007
    i got this after i closed and opened the system
    Error report generated by EFILive at 18:38:22 on Dec 06, 2007
    Error code: ERR_CONFIG/92
    C:\Program Files\EFILive\V7\Configuration\gm_enhanced.prn(130 5): Units gms not found. .
    EFILive Version: 7.4.2 (Build 534)
    Platform: Windows XP
    Version: 5.1 (build 2600)
    Processor type: Pentium 1729MHz
    Directories
    Temporary Cache: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Temporary cache
    Logged Data: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Logged data
    Customers: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Customers
    Configuration: C:\Program Files\EFILive\V7\Configuration
    Exported Data: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Exported data
    Images: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Images
    Sounds: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Sounds
    Maps: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Maps
    Pids: C:\Documents and Settings\Adam\My Documents\EFILive\V7\PIDs
    Virtual Dash: C:\Documents and Settings\Adam\My Documents\EFILive\V7\VDash
    Print Reports: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Print reports
    Bug Reports: C:\Documents and Settings\Adam\My Documents\EFILive\V7\Bug reports
    Connected: No
    Auto connect: No
    Scan OBDII info: No
    Error retries: 1
    Retry delay: 10
    Message throttle: 0
    Most recently used VIN: 1GCHC23142Fxxxxxx (Note: 1)
    PCM information
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Unknown: Unknown
    Stream-Slow scan mode: Unknown
    Stream-Fast scan mode: Unknown
    Maximum dynamic packets: Unknown
    Most recent communication with vehicle:
    Report ID: 155319 (Note: 2)
    Notes:
    (1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
    (2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
  1. oil pressure pid
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 02:27 AM
  2. Nitrous Bottle Pressure logging
    By Beer99C5 in forum External A/D inputs
    Last Post: November 18th, 2007, 01:58 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
  5. Fan A/C Pressure
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 8th, 2007, 10:19 AM
