Download these two files:
http://download2.efilive.com/Softwar...751_028_69.zip
and
http://download2.efilive.com/Softwar...811_011_11.zip
Instructions have been updated, see attached Readme_First.rtf file
If you have already upgraded to the new BB logging bootblock, then you do not need to (in fact you cannot) upgrade the bootblock again. Once it has been done you only need to update the V2.05.xx firmware if/when new firmware is released.
There is new firmware that you must program into FlashScan using the programming option in EFILive_Explorer.
It contains a license upgrade event that will occur the first time you boot FlashScan with firmware 2.5.11 installed.
The low power mode is now active. If FlashScan goes into low power mode, it will appear to be switched off. To re-activate FlashScan, press and hold any key (except Ctrl) until the display lights up. It takes a keypress of about 3/4 of a second. Low power mode can be changed or disabled in FlashScan's settings.
