Results 1 to 7 of 7
Thread: comodore 2007 speed limit
    Sep 2006
    Default comodore 2007 speed limit
    hello guys
    I am trying to increase the speed limt of 2007 comodore from 255km to 300km with no help, I tested the car but it still wont go past 243km?
    please help me guys with your ideas.
    Sep 2006
    hi guys
    anybody find info regarding my problem
    Jan 2007
    I don't know if you can make the speed limit higher unless you disconnect the VSS completely which is not really recommended and illegal.
    http://forum.efilive.com/showthread.php?t=3168
    Here is a thread about monitoring the speed over 255 KPH.
    Maybe you could disable VSS and just watch the trans output speed? Wish I could help. :(
    Set H0156 to 'ECM'
    Then increase H0129, H0157 & H0158 to your desired limit speeds.
    Sep 2006
    Set H0156 to 'ECM'
    Hi Ross
    thank you for repling to me.
    H0156 and H0129 has been done but H0157 And H0158 is not found!
    any idea?regards
    Probably need to update your cal files.
    Details on that are in the thread here -
    http://forum.efilive.com/showthread.php?t=5540
    Sep 2006
    thank you guys for helping me
  1. speed/RPM limit cancel!!
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2009, 05:44 AM
  2. 100 log limit????
    By hquick in forum General
    Last Post: February 4th, 2009, 08:08 AM
  3. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 05:41 PM
  4. HP limit?
    By 80superbu in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 11:00 AM
