Results 1 to 5 of 5
Thread: Can I change the knock sensor frequency.
    Nov 2007
    Default Can I change the knock sensor frequency.
    I am tuning a friends car and keep getting false knock. When the car had the stock modified exhaust it was taking 26* total with no knock. Now he has Borla straight pipes and it reads spark knock at the same rpm every time now. That rpm just happens to be where the exhaust changes pitch. I was looking at the knock tables and there seems to be some tables to change the frequency that the knock sensor reads. Will these tables help me? I don't want to delete the knock sensors but I am only running 20* total and still seeing false knock now.
    Jun 2005
    I'd do it in B6244. Higher numbers = less knock sensor effect.
    Lifetime Member Doc's Avatar
    Oct 2005
    Might have some physical exhaust banging, rattling, etc. I would attempt to rectify that first before I'd jump into the software.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jun 2005
    Quote Originally Posted by Doc
    Yes...my post was assuming this was attempted first. Sorry, was a little tired last night...
    Nov 2007
    The exhaust is tight. We have gone over the car. I will try the table you suggested. I think I did but I went the wrong way with the numbers.
  1. Knock Sensor
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: November 17th, 2009, 12:24 AM
  2. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 08:42 AM
  3. Knock sensor code
    By eboggs_jkvl in forum General
    Last Post: September 23rd, 2006, 07:15 AM
  4. LS1 knock sensor with a LS2 block
    By Camaro SS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2005, 02:27 AM
  5. Knock Sensor Logging
    By daveb in forum General
    Last Post: July 29th, 2005, 10:16 PM
