Alight, so I did a log from 83degf to 196degf. I did a filter, include frames, 80deg above. Then went to an F11 chart.
So my understandings, I need to take what it gives me, and ADD that to what is already EXISTING in my B4307?
Am I correct?
Am I correct?
11 Silverado
08 Sierra
91 RS with 350 TPI and 411 ECM
Yes...copy, paste and add into the IN GEAR column if the car was in gear when logged or into the PARK/NEUTRAL column if it was in park or neutral.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Its standard. But I wanted to make sure I added that to what I already have.
11 Silverado
08 Sierra
