The only change I made to any knock tables was to increase allowed knock to 12 degrees when I found that I was hitting 8 degrees and 8 degrees was the max amount of knock it could pull. With 12 degrees of knock retard allowed, it's never pulled more than 11.7 degrees. So, I'm on the ragged edge there.
What I need to do here is find what's causing the truck to pull so much timing on reducing throttle conditions, not necessarily WOT to full close but where the TPS reading reduces. One point, I had 11 degrees of retard on a 5 percent reduction of throttle. I've also noted high retard at very slow speeds, such as giving a little bump in gas in a line of traffic approaching a left turn to a new road. If I can nail this one thing down, I can put the 3 degrees of high octane timing back in and get the power back that I'm missing.
On the O2 setpoint, here's what I'm running now:
CL Mode Bank-1 Bank-2
0 365.001374 365.001374
8 379.989353 379.989353
16 379.989353 379.989353
24 379.989353 379.989353
32 389.992642 389.992642
40 389.992642 389.992642
48 389.992642 389.992642
56 389.992642 389.992642
64 389.992642 389.992642
I'll look your table over now. Just so you know, I was seeing 19MPG mixed driving on the one tune, just got to get the KR dealt with. If I can, I think I might be able to more selectively adjust timing and tweak up to a full 20MPG with city driving, AND be able to spin the tires through first and into second like it was before. I figure I'm about 80 percent there, and if I can get 20 out of a full size 5.3L I'll feel very confident about getting 25+ out of a 4.8 in my own S10. Or, if I go the way my dad wants me, 30+ out of a 3.8L V6.
