You should also try updating to the latest EFILive software and FlashScan firmware here:
http://forum.efilive.com/showthread.php?t=6646
That update contains a later firmware version: FSProg_V2_4_67.ffw
Thank you Paul. Everything seems ok now.Originally Posted by Blacky
I see the update for
http://download2.efilive.com/Softwar...751_027_69.zip
Should I let that go for now until furthur beta testing is done?
Also I notice I have multiple .ffw files in the V7 folder. Should I delete the old one (and/or should it have been done automatically)?
Thanks again,
Chris
It doesn't matter if those *.ffw files are in that folder or not. They are only used when re-programming the flashScan unit. You can delete them all once you have programmed the latest one into FlashScan.Originally Posted by Leadfoot
