Results 1 to 6 of 6
Thread: Having an issue updating Firmware
    Sep 2007
    Default Having an issue updating Firmware
    I getting the following error:
    http://www.matpa.org/EFILIVE/EFI-Live.htm
    Any help is appreciated. Thank you.
    That error is: "Message too short", which means the data sent to the FlashScan unit form the PC was cut short - for some reason. Possibly due to a fault in the USB connection somewhere.
    Can you please click on the status button to find out the boot block version number it MUST be 2.4.10 - if not the unit will need to be returned to EFILive to be updated.
    If the boot block version is ok, try these options:
    - use a different USB port on you computer.
    - use a different USB cable (any standard USB cable will be fine)
    - install EFILive on a adifferent compueter and try updating the firmware there.
    You should also try updating to the latest EFILive software and FlashScan firmware here:
    http://forum.efilive.com/showthread.php?t=6646
    That update contains a later firmware version: FSProg_V2_4_67.ffw
    Sep 2007
    Thank you Paul. Everything seems ok now.
    I see the update for
    http://download2.efilive.com/Softwar...751_027_69.zip
    Should I let that go for now until furthur beta testing is done?
    Also I notice I have multiple .ffw files in the V7 folder. Should I delete the old one (and/or should it have been done automatically)?
    Thanks again,
    Chris
    Jan 2005
    Unless you'd like to beta test, I'd stick with the release Paul linked you to
    Quote Originally Posted by Leadfoot
    TAlso I notice I have multiple .ffw files in the V7 folder. Should I delete the old one (and/or should it have been done automatically)?
    It doesn't matter if those *.ffw files are in that folder or not. They are only used when re-programming the flashScan unit. You can delete them all once you have programmed the latest one into FlashScan.
  1. Updating FlashScan V2 Firmware
    By Tordne in forum FlashScan V2
    Last Post: November 29th, 2011, 10:57 AM
  2. Updating to BBL Firmware problems
    By WildChild in forum FlashScan V2 BB Logging
    Last Post: November 27th, 2007, 10:12 AM
  3. Updating to BBL Firmware problems
    Last Post: November 25th, 2007, 05:32 PM
  4. EFILive V2 Firmware Updating Instructions.
    By eboggs_jkvl in forum FlashScan V2
    Last Post: June 26th, 2007, 09:19 AM
