I'm looking at a tuned 01 SS ... it has a Cam somewhere in the range 248/252 with .6something lift, probably stock injectors, AFR heads, long tubes, off-road Y-pipe w/o cats, Fast intake, 90mm TB, SLP MAF ...
It was dyno-tuned previously by TTP, but some stuff looks fishy to me ... e.g., the B0101 table is pretty high, with 90+ values in the mid RPM range ... also, CL right from starting the car at 15 degree C ... maybe somebody can look at the log and the tune and give me a quick feedback on what you think ... the logg is from starting it up cold and running it a couple minutes, the .tun is the current tune ... oh, the plugs were messed up pretty quickly, no telling if it was due to cranking it after the ship-travel over the Atlantic, or because of the tune ... current plugs are new ...
Thanks in advance!
