Last night I checked the latest update by scanning/flashing/bbl my truck(E38/T43) That all worked fine. This morning when I got in and started it up there was a SES light on so I checked the DTC's(V2 did this fine also).
There was one for the ECM and one for the TCM. I didn't have anything to write them down with and was in a hurry. I know one of them was P0700 and the other was something strange like UC0730(may not be right). I cleared them which the V2 did fine again.
Before I backed out of the driveway I started recording data and everything looked fine. The drive to work was 44 minutes and when I got there the timer was still counting but, the data was frozen. When I tried to exit logging, the V2 never saved any data in the file. The file was there on the SD card but, it was only 2KB in length which I'm guessing is just from stuff in the file that EFILive uses. No actual data was logged. :(
When I used the BBL last night I just tested it for about a minute and it saved the file fine. I'm not sure how far into the trip today the V2 got messed up since there was no data or time log to look at.
On Monday I will try to log again on the way to work and keep an eye on the unit to see if it messes up again and how long it takes.
Just a heads up on a possible issue.
