Have 92 blazer, push button 4x4, it won't go into 4 wheel, can hear it clicking underneth when pushing button , but won't go in
Most likely the actuator motor.
I think on yours it's located on the front diff?
Try unplugging and cleaning the connections.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
